The vtec solenoid should work even if the gasket is damaged. Sure, you will leak oil, but that shouldnt affect vtec engaging. Low oil pressure will cause vtec to not engage. Notice when vtec engines are cold, and you try to rev up to vtec crossover... nothing. The engine cannot build enough oil pressure when the oil is cold.
