stock'sLS/VTEC
I just finished my fully built ls vtec.... and I am wondering if crome will be a good choice to go with for a tune? and I was wondering how much a good tune would help? these may seem like dumb questions but I am trying to get some advise from someone with experience using crome, or other systems... I dont want to spend a ton of money on a EMS
I am currently using a jdm p30 ecu! Is it worth getting a test pipe?
2.0 L w/ GSR b18c1 head
Bored
Stage 2 port n' polish
performance 1mm over sized pistons
headers
intake
exhaust
pulleys
stage 2 cams
skunk2 tuner series valvetrain w/ titanium retainers
skunk2 cam gears
new ITR valves(sam as GSR)
70mm throttle body
Blox intake manifold
3 angle valve job
milled only 10/1000's
VAFC
skunk2 short shifter
fuel pressure regulator
JDM p30 ecu
How much whp should I pull? and 1/4 mile time? at sea level
**** O and am I completely screwed if I did not replace the rods or bolts??? ****
Bored
headers
intake
exhaust
pulleys
stage 2 cams
skunk2 cam gears
70mm throttle body
3 angle valve job
VAFC
JDM p30 ecu
