'00 Si Cluster Swap questions
  • Thread starter Thread starter SeVeNisOnE
  • Replies Replies 1
SeVeNisOnE
Ken Korn Karn
So I have a '96 EK Hatch. The speedo recently stopped working on my Si cluster which was swapped in. So I figured it might be the VSS. Tested the OEM sensor and it is sending signal. So I swapped out the cluster with the original working piece and it works fine, so I firgure its the actual Si cluster. I like the way my Si cluster looks, so is there a way I can swap the parts needed from the old cluster to get the Si cluster to function again? I don't want to buy another Si cluster.
