2000 ody van wont start
  • Thread starter Thread starter automatim
  • Replies Replies 1
  • Views Views 741
automatim
I have not seen a whole lot about the Ody here but here goes. I have an Ody that will not start without applying some throttle. When not on the pedal it will try to start but the stall imediatly. If i give it just a little pedal it will fire up and run... until I come of the throttle it stalls. Truthfully it a won't idle problem that came across as a no start problem. Also what do I short out to pull code on this thing. I looked evey where and could not find a 2-pin connector. I do see a many pin connector mounted under the dash. on the drivers side of the console. Any ideas? HELP please.
is there a definite check engine light though? if it's a 2000, places like autozone or schucks will pull the code for free. i would take it there and then come back and post what the code is. it could be anything from a distributor to starter or fuel problem. the plug for pulling the code is near the ecu, but other places will pull it for free so don't even mess with it.
