khai_tuan_nguyen
Originally posted by Calesta@Sep 1 2004, 12:01 PM
Ignition timing maps? There's a lot more to timing than the base measurement.
[post=384731]Quoted post[/post]
Is ignition timing with the distributor?
What other factors determine timing besides cam and distributor?
Obviously I don't much. So here is the story. I had the p72 obd2 ecu and had to turn dist timing to 14 and cam timing at factory to stop it from pinging it still pinged. I got p28 ecu and hondata s100 and obd2a-1 conversion. We kept cam timing factory and even adjusted distributor timing as low as 0 and it still pinged.
What are some other possibilities for the pinging and what are other possibilites to stop it besides the lower compression pistons and race fuel?
What am I mnissing
Thanks for the patience.
Khai
