P projectxspeed Senior Member Feb 6, 2005 #1 Is it possible to use the black top 2G 450cc dsm injectors in an obd1 1995 integra ls. What do I need to wire them in?
B beerbongskickass Senior Member Feb 6, 2005 #2 A resistor box from a CRX or resistors from radio shack. You can just bore out the o-rings with a dremel. http://www.homemadeturbo.com/tech_projects...tors/index.html
Speedracer228 ...... Feb 6, 2005 #4 yes, follow the link provided by beerbongskickass and do as instructed
B beerbongskickass Senior Member Feb 7, 2005 #6 Originally posted by projectxspeed@Feb 6 2005, 08:24 PM Even with the 95+ injectors? [post=457221]Quoted post[/post] Click to expand... I am using blacktop injectors in my 95 civic.
92civicb18b1 The Trisexual Feb 7, 2005 #7 I think the ones I used on my first set up were 98's, they worked great.
ryan89crx Senior Member Feb 8, 2005 #8 what are the differences between the Bule and Black tops? are there any different things you have to do to get them to work in an obd0 or obd1 car?
