450cc injector install
  • Thread starter Thread starter lude68
  • Replies Replies 8
lude68
Hey guys! Im on a budget build w/ my lil bros turbo build (instead of N/A after i bought him CTR pistons..ahh kids) ...anyways my question is what will have to be done to run 450cc injetors out of a DSM on a 94 gsr motor? and will it work fine w/ a 190lph fuel pump?
Thanx for the advice.
if it is a 92+ honda/acura you will need to run 10w 10ohm resistors on the yellow/black injector wires (+12v) because the DSM injectors are low impedence (~2.5ohm). fuel pump should be ok.
how to wire in resistors? you'll need 4, one for each injector, and it splices into the yellow/black wires on each injector which is the 12v power supply.
Go to homemadeturbo.com they will show u every step to do it. u will need to use some type of fuel control unit. My friend program a chip for my ls/vtec turbo using the 450 dsm injectors and my car run fine. If u need more info e-mail me :D
my friend got cheap resistors at radio shack on his budget turbo setup cheap as hell so if you dont know where to get them ...radio shack is the shit
:werd:
tis where i got mine, the 10w 10ohm ones, cost about $4 for all 4, come in packs of 2
i think lsdiodes.com sells em for cheap, I know when I bought my LEDs it was 10 for a quater or something like that but they charge u 4.95 for handling
