5th gear & final drive swap
  • Thread starter Thread starter gnposse
  • Replies Replies 1
gnposse
Hi guys,
Do you any of you know if the 5th gear and final drive of a (P20/A000 transmission) 92 Civix VX/CX would work in my 91 Civic DX 5spd tranny (L3)?
I can order the gears from a local Honda garage & install them myself.
Or should I just swap in the 92 VX/CX transmission? (if I can find one!?)
I am trying to increase MPG! Exxon is getting to much of my $$.
Thanks
the 5th gears will swap into it - the final drive won't - the 92 transmission will not bolt into your car - you would need to fabricate mounts and convert it from hydraulic clutch to cable clutch - why not get a 89-91 CRX HF transmission if you want longer gears?
