you can use the 88 Si PM6 ECU with the ZC - better to get 88-89 integra PG7 because of higher rpm fuel cut-off, but you can use PM6 - with the ZC transmission, you must use ZC intermediate shaft and 90-93 integra axles - stock axles, where they go into transmission, are smaller diameter spline and don't fit
