89 crx problems running
  • Thread starter Thread starter gunz2165
  • Views Views 807
gunz2165
i had a problem with my 89 crx running. it wouldnt stop sputtering and spitting while i was driving. i changed the fuel pump and it was ok for like a ay then it started again. i drove it to the gas station and filled up. it only took 1/4 tank so i knew i wasnt outta gas, then it was fine. later that same nite i went to drive it and it was acting the same way. can neone tell me what the hell it might be? i sold the car and the guy is coming monday to get it and i gotta have it runnin straight by then. someone get back to me asap.
I appreciate the help
oo the engine is a 91 acura ls
Have you changed the fuel filter? Check your plugs as well. I am leaning more towards bad fuel filter.
:withstupid: also check your fuel relay, my crx was acting up and it turned out to be the relay after I replaced the fuel pump also
