Hello,
I’ve managed to score a set of rear disc brakes from a 91 CRX Si (complete trailing arms with all lines/cables/rotors/calipers). And, I would like to throw this into my 89 CRX Si.
I just need a little reassurance here, do I also need to change my master cylinder, brake booster and proportioning valve? Or will I be ok with just swapping the trailing arms?
I’ve already done a bit of research on the web regarding this … but I didn’t find much information about the master cylinder/booster/proportioning valve.
Thanks in advance
Thanks in advance
