91 EF B16 help
  • Thread starter Thread starter JuanWho
JuanWho
I have an 91 EF with a B16A swap in it. I bought the car swapped and I have no clue what tranny I have. I recently blew the tranny, and decided to rebuild it. I need a few things for the rebuild that I ordered off Acurapartwarehouse, but everything I got was with a diameter of 1 /34 of an inch. I compared them to the parts I had on the trans, and the ones on the trans are 1 1/2 inch in diameter.
TL;DR, I need help finding out what gears I actually need.
Code:
[B][SIZE="3"][COLOR="Black"]Part Number:   Description:[/COLOR][/SIZE][/B]
[COLOR="Red"]23442-P16-315	GEAR SET, MAINSHAFT THIRD [/COLOR]
23451-P80-V00	GEAR, MAINSHAFT FOURTH
[COLOR="red"]91205-PL3-A01	OIL SEAL (35X56X8) (ARAI)[/COLOR]
91205-PC9-711	OIL SEAL (40X62X8) (NOK)
[COLOR="red"]91216-PH8-005	OIL SEAL (28X41X7) (NOK) [/COLOR]
91215-689-013	OIL SEAL (14X25X16)
You (most likely) have a cable transmission. But you may have a hydro to cable conversion with a newer trans.
Is it a cable all the way from clutch line at firewall to the trans?
Probably a B16a SiR1 trans or a cable Integra non-VTEC trans. There are cable GSR trans but they are more rare and less likely in your car. Look for engraved number/digits on the trans case. That will lead you to the type of trans on there so you can order the correct parts. It should be one letter and two numbers like "S80"
