94 Civic LS swap Mount Questions
  • Thread starter Thread starter SPL KID
SPL KID
Is it neccesary to to have the front AC mount stopper Bracket and Bolt down? Thats a expensive piece and I don't see it used in many other swaps of earlier models.
Well the A/C bracket is actually a torque bracket that you really dont need but it does help. I ran my car without it for a long time after I removed my A/C.
if your using swap mounts then chances are you don't need it. Specially since most swap mounts are solid Urethane.
I just did the same swap and did not use the a/c mounts or the one on the other side either. I have noticed no difference either. I used the factory motor andtranny mounts also. I intend on changing to the hasport mounts eventually. But to answer your question, you dont really need them.
