Unmolested hatches are a rarity in my area, but one finally popped up for sale with only 100k miles and I snagged it. It's a factory manual coming from the south, so there's virtually no rust. So far as I can tell, for the money within my price range (3k for the swap), my best option is a LsV build with spray or a turbo down the line. For now, I just want to figure out what I should do about the motor- rear disc conversion, coilovers, a suspension bushing refresh, and fresh rims and tires are all on my list.
I've got the stock y7 in there still- if I understand correctly, all I need is a mount kit and then my engine and trans will bolt right in- fuel lines, exhaust, and everything else will not need to be modified. I'll need a shift linkage, harness, ecu, and axles, but that's about it, right?
But, if I want the car to pass inspection (by swapping out a hondata ecu for a stock one when the time comes), won't I need a OBD2 block and head? If anyone could clear this up for me, and maybe give me their input on what route to go, that would be great.
