99 si cylinder misfire help
crxsi88
the car studders in low rpm range...smoothes out after you get into high rpm. any ideas of what could be wrong?
Cap rotor coil plug wires plugs. Check all of these first. Sounds like a ignition problem. Also bad gas make sure your running high grade. It is a 10:1 CR it needs it. New fuel filter?
