ACL Main Bearings
  • Thread starter Thread starter eroman
  • Views Views 896
eroman
I just bought a set of standard ACL duraglide main bearings for by B18A, but there is no color code on them. Are they one size fits all? Someone told me that they are all basically green. Is that true? If so, what do I do if I require other colors? :unsure:
OK, so I'll use the one size ACL bearing for all five of the mains, check the clearance with plastigauge, and I should be cool, right?
honda uses 5 sizes, ACL's 1 size is right in the middle of all 5 which is green by Honda standards. As long as you crank,main journal, rods, etc haven't been drasticlly honed, polished, messed up...they should easily be within factory clearances.
matt
matt
[post=396183]Quoted post[/post]​
Thanks
