are these the axles i need?
  • Thread starter Thread starter 96ekhb
  • Replies Replies 6
  • Views Views 903
96ekhb
Member
Ive heard different things from different people. Im in the process of swaping a b18b in a 96 dx hatch. Which motor mounts do i need? 99 si or 94 - 01 integra? Im pretty sure I need the 99 si rear engine mount and front drivers side mount. but should i use integra mounts for the rest??
are these the mounts i need below? if so are the any good?
front left engine mount
http://www.partsamerica.com/ProductDetail....type=27&ptset=A
rear engine mount
thanks for the help guys
DOING THE SAME SWAP MY SLEF YOU CAN USE THE INTEGRA FONT BRACKET THE ONE ON THE ENGINE FRONT BOTTOM AND ALSO THE TRANS FRONT BRACKET ALSO ON THE BOTTOM OF THE TRANS YOU CAN USE 94-01 INTEGRA AXLES OR 99 CIVIC SI AXLES ITS UP TO YOU. NOW IF YOU WANNA KEEP THE A/C IN YOUR CAR YOUR GONNA HAVE TO USE A DEL SOL VTEC 94-97 FRONT ENGINE BRACKET. IF YOU HAVE A MANUAL TRANS THE TOP BRACKET YOU CAN REUSE IF ITS AUTO GONNA HAVE TO CHANGE TO MANUAL BRACKET. HOPE THIS HELPS LET ME KNOW.
THANKS STEVE
THE MOTOR MOUNTS YOU CAN USE YOUR STOCK ONES OR UPGRADE TO HASPORT OR HCP
[post=484276]Quoted post[/post]​
:wtf:
whats with the CAPLOCKS?
:w00t: and yeah..Like he said, you can upgrade to hasport mounts...or use stock ones....
[post=484273]Quoted post[/post]​
are you sure about the 94 - 97. i heard it had to be 96 - 97??
There are two different DelSol brackets, the P30 and the P54, use the P54 on B series into 5th gen to save AC, both will work, just one won't mount the d series compressor
