im pretty sure you need to modify the auto ECU to work right on a manual
or just get the manual ECU
but i dont think you can run a manual with an auto ECU (same thing the other way around)
There is no difference in rev limiter I believe, which ecu are you referring to? 5 speed engines can run auto ecus fine, not sure if it works the same way, though.
Originally posted by Afipunk21@Apr 22 2003, 02:14 AM There is no difference in rev limiter I believe, which ecu are you referring to? 5 speed engines can run auto ecus fine, not sure if it works the same way, though.
ive had the car for maybe a month, i was just told that the limiter is different, i am running the 5speed with Auto Ecu.... would it be better to find a Man. ecu? where could i find one?
Hmmmmm i really dont know much about this motor or ecu... i looked and looked and didnt see any other #'s except the ones i listed below, im afraid to take the ecu out to get a better look because all of the connections were poorly down (twist connectors )
