B Series Distributors
  • Thread starter Thread starter joe654891
  • Replies Replies 6
joe654891
Hello,
Does anyone in here know if any B series distributor fit and/or will work on my 94 gsr swap? Not sure if this is the right forum. Anyway, if any of you know I really would appreciate any insight on this. Thanks in advance...
~joe
(n00b) :D
Any distributor from a B series OBD1 DOHC VTEC engine will work.
An LS distro is a ghetto fix. You have to cut a leg off and the timing is goofy.
OK...I've been doing some reading/research and if I get this correct, the distributor I use depends on the ecu I use. Is this correct? I'm still kinda "fuzzy" on this. If anyone can clarify this for me or point me in the right direction, I'd really appreciate it.
~joe
The distrbutor is linked to your ECU by the version of which O.B.D. you have, or "OnBoardDiagnostic."
OBD1 ecu's will match to OBD1 distributors
OBD2 ecu's will match to OBD2 distributors
The 94 GS-R is OBD1, so you'll need a distributor from a pre-96 Integra.
OK I get it now. Thanks for clearing that up fellas. I really appreciate the help :worthy:
~joe
