b16 ----> b18 swap in EG
  • Thread starter Thread starter Mr2d2
  • Replies Replies 1
  • Views Views 2K
Mr2d2
Hi guys, I picked up a b16 swapped eg hatch a few months ago and have just decided to "personalize" the car a little. I think I'd like to use the b18 though for the extra displacement. I was wondering how much work would have to be done to swap the motor since the b16 has already been put in. I know I'm already using gsr axles, but what about the motor mounts, wiring, etc... ??
What type of b18 are you putting in? If its a B18C/C1/C5 everything will bolt up the same, even wiring (granted you arent throwing any CEL's and vtec is working properly), you will just have to get an ecu in accordance with the motor your putting in. Even if its an LS swap your putting in, everything will bolt up the same. You'll just have a lil bit of unecessary wiring thats all...
