jtornado New Member Sep 22, 2007 #2 nevermind I found specs myself. Forget thread. The compression will be very low
K2e2vin Senior Member Oct 11, 2007 #5 jtornado said: stock gsr pistons?????? Click to expand... I doubt it; B16 pistons have larger domes than GSR, and larger domes than USDM ITR's too(not sure about the JDM ITRs).
jtornado New Member Oct 11, 2007 #6 well although the gsr rod length are longer than b16 so therefore that raises compression too.
K2e2vin Senior Member Oct 15, 2007 #7 Well, you're suppose to use correct rods. B16s have shorter block height than B18s.
