Hey guys whats going on. I have a 99 civic dx (ek) with the horrible d16y7. I just bought a b16a3 from hmotorsonline and just got it in the other day. Before i start pulling my motor out and putting in the b16 i just had a few questions about the wiring situation. Things i revieved with the swap are...
Motor
head
ecu
axles
all the correct mounts
0bd1 ecu
0bd1 engine wiring harness
tranny
shift linkage
basically the whole ball of wax, im getting the 0bd2b-0bd1 jumper and i know that will take care of the wiring situation under the dash, but as far as the motor harness goes im just confused as to what exaclty i need to use. I have been doing tons of research and havnt been getting a straight answere. Can i use the y7 0bd2 harness and swap over the plugs/sensors over from the 0bd1 harness? I just want to make it a plug and play and not have any suprizes when i go to fire the bitch up. Any suggestions about the wirring and or anything else i might need to this swap to just be plug and play? Thanks anything will be a big help!!
Motor
head
ecu
axles
0bd1 ecu
tranny
shift linkage
