obd2b car and put in a b18, ive used the obd2b ek4 loom with a chipped p28.
I thought this would all plug and play but i have some problems...
The car seems like it doesnt want to run?! it barley idles and around 1.5k the revs bounce until i give it some more gas and will rev upto 4k
its throwing up ecu codes;
6 Engine coolant temperature
10 Intake air temperature sensor
14 Idle air control valve or bad ECM
22 V-TEC pressure solenoid
messed around / cleaned all of these and still the same?
also i have these sensors/plugs left over..
What is this plug for?
which one is the engine coolant temp?
Do i have two Intake air temperature sensors? one on inlet runner and one in induction pipe?
I will be grateful for any help!
