B18a in EG axle question
  • Thread starter Thread starter ttboostboy
  • Replies Replies 1
ttboostboy
iI couldnt really find anything conclusive so heres my question. I have a 93 B18a and i have a 95 gsr trans. Its going into an EG. I have axles off of the EF that had the motor before my car did. Can i use the cable trannys axles on a GSR trans or do i need new axles? or is there some way to possibly change out the halfshaft?
You are going to need new axles. Get the ones for a GSR transmision. I have those in my car, they will fit your hubs and your S80 transmission. Actually you should be able to use axles from any B series with the exception of the Type R and CRV axles with your EG as those axles require bigger hubs (36mm) I believe.
