B18a into 94 honda civic
  • Thread starter Thread starter 94Civic-eg
  • Replies Replies 3
  • Views Views 973
should I go with the LS-VTEC or LS w/ turbo
  • LS w/ turbo
    Votes: 0 0.0%
  • Natural asperated
    Votes: 0 0.0%
  • Total voters
    3
94Civic-eg
What parts can I reuse and what do I need to get? Im planning on boosting too but I need to know if my stock ECU will work with that engine. Right now I have the d15b7 and want to change over to the B18a1. I know i will need harness, tranny, and mounts. Just need to know if my stock ECU will work or will I have to replace to the 90-93 Integra LS.
Stock ECU will start and run the motor, but not well.
You can use the block for a LSvtec.
You need a hydraulic transmission.
You must change it to OBD I, if it is not already.
92-93 B18A1's are already OBD-1
use n OBD1 head for the vtec conversion 92-93 GSR Integra, 94-95 GSR integra, 92-95 SiR (B16A3 I think). Unless you want to rewire the car.
Use: S4C, Y80, S80 or S21.... otherwise any hydro B series transmission will work.
