Quoted post[/post]]
Quoted post[/post]]
from your previous post where you said the distributor plugs didn't match, i assumed you had the OBD0 B18A1 engine and if plugs didn't match, your car would be a DX - now that i know you have the HF, if the plugs don't match, it would mean your B18A1 engine is OBD1 - is this correct? if so, you will need to either convert the engine to OBD0 or convert the car to OBD1 - the HF distributor won't bolt to the head - your question about the O2 sensor depends on whether you are going to be using OBD1 or OBD0
how can i tell what it is obd1 or obd0 ?
what should i use obd1 or obd0 witch is better or easer to do?
is it easer to change the motor or the car over?
i had swaped over over the motor wiring harrness from the hf motor.
not shure on what to do first time swap.
