timing belt mount is known as a post mount. its the mount that bolts DIRECTLY ON TO THE BLOCK with 2 studs sticking out of it.
the tranny mount is not necessary if your ex motor *d16y8* is 5sp. you can reuse that mount.
no u cant u need a b-series lower tranny mount and a 99-00 si top tranny bracket, please dont try arguee because i have the swap done on my 98 ex
I ordered it just like you said as seeing you already have it in your car I will go with your info.
