Bad battery?
check your power and ground wires for corrosion, and clean them if needed. My truck did this to me recently.
Was your battery old? I would first replace the battery and the main relay and then see what your car does next. Sometimes a few unrelated things will go at once on an older car.
do you have a votl meter?
the battery should read 12 when the car is not running if it dosn't then charge up the battery a check again if the volt meter shows a drop than your battery is shot. If it dosn't read 14.4 when the car is running then the alt is bad
