Anything that is bent in your suspension is going to cause undesirable effects. I would replace anything that was damaged and consider getting an alignment also.
Why don't you get under your car and look? I bent my driver side LAC at an AutoX event and its noticable if you sight along the spine of the LCA when you're under the car whith the tire off.
