hey guys,
i picked up a brand new set of faze guages, a boost and an oil temp. hooked it into my rehostat for my dim switch, and the guages work awesome, you can dim them and everything, but my whole fuckin cluster went dead. no tach no lights, no anything, everything just unplugs as you probably know, unplugged it all pull the cluster, installe the guages, tapped into the 1 wire i needed, and put it back together and its all dead. the clock doesnt even work (93 del sol has the clock on the cluster) the only light that comes on with the key on is my oil light, but its very dim and when you turn the dimmer switch it gets brighter andlower, but no seatbelt light or batter light or SRS light with the key on. any clue??
i havent messed with any grounds or had anything else apart. i check all fuses and they are all ok!
