lostsoulzprophet
delslow
any car meets this weekend up in that area. i might try to go to one. bring the sol out somewhere new.
The wheels and tires look much better. Next step should be a hood, then paint, then it'll be looking pretty sweet.
to all that, but add a camber adjustment for good measure.ive spent a winter in georgia. i do not feel bad for you.
i agree with you on that. i did not grow up in ga. so winter here im pretty much walking around in shorts.
they are 15x7's with 205/40's with +15 offset
Thanks! 205/40-15 is a little short isn't it? What's the camber like?
On 15" wheels the sidewall of a 195/50 is OEM for height and overall tire curcumference for the 4th generation Civics. 195/50 = 97.5 mm sidewall height. 205/40 = 82 mm sidewall height. The circumference of that setup is less than OEM or "Short" for the overall gearing. On my ride I went to 205/45-16 which is just a bit taller than stock to correct the speedometer error.
For camber, the picture appears to be way off on the front and off on the rear with excessive negative camber numbers. Stock there is no adjustment for camber on these models. To correct rear camber, when it's negative as it appears for this ride is simple. Just pull the bolts on the upper rear arms and put some washers under them to shim out the arms.
For the front, there are a couple of different aftermarket kits that will work.
Judging from the pictures, it should be corrected to steer correctly, especially under power, and for optimal tire wear.
nah they fit pretty decent, and the camber int 2 bad, I honestly dont know the camber adjustment
