Well, measure it then.
Find out what your stock spring rates are, find out how much you want to drop, then crank the spring rates up until it takes the same amount of force to bottom out your car as with the taller softer stock setup. You could just go ultra stiff, like 500-600 pounds/inch up front, and then you wouldn't have to worry about bottoming out, even with a 2 inch drop.
wat does that mean?? spring rates?? im not too big on suspension stuffOriginally posted by lsvtec@Sep 17 2003, 05:22 PM
Your roads must be nice and smooth, I am not sure what the rates on the H&R springs that I am running are but I am sure they aren't that high and they are almost too much on the beat up roads here.
Originally posted by Calesta@Sep 17 2003, 02:12 PM
Nah, I'm running just a tad over 500 lb/in up front, and it feels damn good.![]()
448 lbs/in front
336 lbs/in rear
in the del sol
fun stuff
Originally posted by h22poweredgsr@Sep 17 2003, 06:45 PM
wats the diff btwn race springs and sport springs?? is it jus the spring rates??. im goin w/ a tokico illumina struts and progress springs. how does that sound?
