cheap gsr block and misc b series
SoSlo
stuff for sale:
B18C1 block with mains and gurdel $125
B18C1 crank (needs to be micropolished on one jurnal) $75
p72 un tapped oil pan make offer
p72 water pump(used) $20
obd2 crank angle sensor $25
gsr head bolts $25
arp gsr rod bolts (new in package) $50
b16 rods $20
gsr throttle cable $10
jdm gsr injectors obd1 $25
2x gsr crank pulley $15
misc 2.5 inch steel tubing make offer
turbo 5 bolt flange $15
blue steering wheel with air bag $40
driver side manual eg mirror $10
2x 2.5"-3" coupler $10
3" t-bolt clamp $3
vx front spindles with brakes and rotors $10
vx rear drums with e-brake cables and arms $10
vx brake master cylinder $5
everything is OBO
if interested hit me up at smmccurdy@hotmail.com
lacated in washington
things i really need
low comp pistons for a gsr
aftermarket rods for a gsr
aftermarket radiator for a 92-92 civic
Originally posted by brian11to1@Aug 25 2005, 09:04 PM
how much for the gsr block, crank, pan windage tray oil pick... etc... 85323
[post=545374]Quoted post[/post]​
Damn Bri... I think you just got lucky,.... ;) Just what you were looking for....
i dont have the oil pickup but i will send you this
gsr head bolts $25
for $200 plus shipping
i will check on shipping tommorow morning and let you know
i need it gone by sep 7 since the army is moving me and i dont have the room for it
i have paypal
slohybrid is my ebay name for vouches
[post=545387]Quoted post[/post]​
Bout time, eh?
SoSlo
@Aug 25 2005, 08:53 PM
gsr head bolts $25
i have paypal
[post=545397]Quoted post[/post]​
Ok, sounds good. Are the head bolts used? If they are, are they any good? I really need that pick up... does the block come with the oil pump, front and rear main seals? What does it not come with?
the head bolts are used but still look to be good
ill even throw in the stock injectors
here are are some pics
Find out shipping and Ill figure out if I'm going to use it. And what exactly are you including with the deal. Also, I dont need a lot of parts sitting around.
So, in reality Im not going to need the headbolts or injectors.
I will take: Block, Crank, Girdle, Pans, Front and Rear Mains, Main, Water necks, Water tube (goes from water pump, to thermo housing), timing belt covers (if you have them) Let me know what you've got exactly
it is apart cause that is how i recieved it. i dont have the oil pan or the front seal or the belt covers. i am including everything in the photos
[post=545444]Quoted post[/post]​
Alright, well as soon as I get a response on 2 others, I'll let you know. That's too many more parts I would need to buy.
intersted in block, oil pan. shipped to 02719 MA. where u located???
hit me up on AIM...B18 Honda EG
crank pulley and 5 bolt flange too
if brian passes the block up, how much do you want for just the windage tray and the thermostat housing?
