Cltuch Pedal Adjustment
cyphen
self explanatory question....i want to adjust the pedal height on the clutch pedal...is that possible and if so how...cant find the fucken book anywhere here.... :(
i know there is if its a cable tranny, i just adjusted mine last week. There is a threaded cap on the clutch bracket that mounts to the tranny. good luck!
the problem with adjusting it is that it will fuck with your clutch.
too high, and it won't hold
too low, and you will grind every gear because it doesn't release all the way.
thats what the adjustment is there for- to get the sweet spot of grabbing and not grinding, not because you are a lzy ass and don't want to move the pedal the whoel distance :p
