Code 16 and Code 43
importimage
My car runs for about 15 minutes then I get a code 16 and code 43 come up.
I recently had my main relay re-soldered, fuel injectors cleaned and new fuel filter installed. I thought that these checks and replacements would rid of these annoying codes.
-I am going to change my O2 Sensor.
-I have not checked the fuel pump....but it should be good. It is a Holly.
Does anyone else have any ideas??????
_______
under the articles section there is a reading about trouble codes. look there first and then try to fix the codes!
Darin
turn the key to on, but not turn the car over. listn closely, and you should hear the pump turn on under the rear seat.
When I turn the car on Ac, I do hear the pump turn on. Does this indicate that the pump is good? I have heard some people talking about a fuse for the fuel pump. Where is this fuse??? or do they mean the main relay (Not a fuse)?
