still havent checked anything... done throwing money at it till i can diagnose the problem
new bits of info though.. while sitting at idle... when you go to press the gas, it starts to die out unless you give it more gas.. .like if you rest your foot on the gas pedal, the rpms should climb very slowly and hold at one point...doing this make the engine stumble and want to die, exact opposite of what it should do
**edit
another thing too.. say the car has been running, shut if off and restart it a few minutes later.. it has a really hard time.. barely fires up and rpms stumble for sec then creep up to normal... when Jen gets home from work i'll take the videos of what i'm describing
