The bushings are pretty cheap, however, they are impossible to install. The dealer will tell you to buy new ones because it makes the hole job alot easier. What I would do is buy LCA's for an integra or del Sol VTEC so that way you can put a rear sway bar on your sol. Go to a junkyard, find a wrecked Integra and take the swaybar with brakets, endlinks, and LCA's. The Stock integra's sways are not really agressive so you dont have to worry about subframe tear out, having your tail end swing out around everyturn, ect. You will notice your car does not push to the outside and will handle a little bit better. If you can get the whole thing from a junk yard, it will probally cheaper then getting new Del sol LCA's from the dealer.
