Swapping a B20B VTEC into 92 hatch. I wanted to use the chipped P28 i have. The engine harness I'm using is 98 GSR. anybody know i can achieve to use the P28 on this?
If the car is wired for vtec its plug and play and if its not you just have run a couple wires to the ecu. As luck would have it running vtec wires is the featured article this month so you're set
Use the GSR harness, it plugs right into your Civics canon plugs, no adaptre or anything. Have the P28 chipped to run that motor, and plug it right into your ECU hanress, pretty simple. No need to use or modify your stock harness.
