Crome with vafc??
  • Thread starter Thread starter gettocrx
  • Replies Replies 8
gettocrx
I'm currently running crome on my b16 turbo. I'm planning to up the boost from .4bar - .6 bar or maybe little more:D . When I do up the boost, I'm planning to run my friends wideband to see if the crome basemap is safe. If its a little lean here or there, Do ya think I can fine tune the fuel curve a little with the vafc2? since i already have a vafc. I don't think I may need to since John (phearable.net) made me this map. It's just a thought!
I used hacked for awhile! so its already installed! But anyways it was just a thought!:shrug2: I'll just use as a meter, I guess!
just retune your Crome map to compensate for the higher boost
^WERD. If you already got a base map from someone thats working for you, odds are its going to be close when you run higher boost. Keep an eye on the Wideband and make sure you're not dipping out of the 12 or 12.5:1 area. The timing should be pretty good.
