MazdaAspec
/\ IDIOT ALERT /\
Does the car even crank??? Fuse was my problem and also if an oil leak she will not start if there are a lot of things done to the motor. Those were my two problems due to a gasket that i get to fix weekly.
if your doing a headgasket that often then either our not doing it right or there is something wrong with the motor..and the car does crank its just not getting sparkDoes the car even crank??? Fuse was my problem and also if an oil leak she will not start if there are a lot of things done to the motor. Those were my two problems due to a gasket that i get to fix weekly.
ignition module ftw.
