d16z6 block d18y8 head+trans=$800
  • Thread starter Thread starter triniDEMON
  • Replies Replies 1
i'M getting a DI6Z6 BLOCK WITH A D16Y8 HEAD ON IT +HYDRO TRAND,DC HEADERS,LIGHTEN FLYWHEEL ,NEW CLUTCH(PERFORMANCE) WATER PUMP AND TIMING BELT DONE A MONTH AGO AND PORT AND POLISHED HEAD.
THIS MOTOR HAS 8000 K...ON IT
I AM ALSO GETTING THE D16Z6 HEAD AS SPARE
ALL 4 $$$800
ITS BEEN DYNO TESTED AT 152HP @6000 RPM(WITH CHIPPED ECU)
I SAW THIS MOTOR B4 IT WAS IN THE CAR AND WHEN THE MECHANIC PULLED IT OUT OF THE CAR 2 SWAP IT 4 A B18C1
MOTOR IN MINT COND...DRIVER REARLY DRIVES IT(HE ALSO OWNS A TYPE R)
IF I BUY IT ALL I NEED IS A ECU
I KNOW THE MOTOR THE OWNER AND THE MECHANIC(BOTH NEIGHBOURS)
U THINK ITS A GOOD BUY????????
PLEASE REPLY????????????????????
TURN OFF THE CAPSLOCK, IT IS ANNOYING, SLOW DOWN AND TAKE YOU TIME WHEN YOU WANT TO ASK A QUESTION, WOULD YOU RUN UP TO SOMEONE IN REALLIFE AND SCREAM A QUESTION AT THEM?
If you know the mechanic, owner and motor, than sure, not a bad deal, as long as it is in good shape.
