DA linkage legnth for EF B16 swap
  • Thread starter Thread starter Drunkencat
  • Replies Replies 8
Drunkencat
I've looked everywhere and I cannot find how much to cut off of a DA linkage for a B16 swap I am putting into my 91 civic si. I do understand there is wielding involved, and its not a problem. I just cant see in spending $150 for a linkage when I can wield it myself. Thank you in advance for your responses.
not sure but you could always install it then put it up to the tranny and then you will know how much to cut
i mean once you install the shifter and the linkage to that the other end you cut and weld you can see where they need to bolt to
I can verify 2 3/8 in. should be cut, I did the same on my ef, just remember to mark their positions BEFORE you cut. Also I learned that the metal is pretty soft so I had my welder on low cause I nearly blew through the metal.
Great thx for the info. I'll keep the setting low and I assume I would cut from the middle section of the linkage.
