ok...here's the deal...i have an Sir2 motor in an 89 civic and i was using a pr3 ecu so i changed out the distributor to an obd-0 one so it would corrisponde with the ecu...now problem is this...what do i do now so the wire harness side for the distributor will plug in? as you know the Sir2 has grey square plugs and the new distributor (SiR) has white round plugs. Do i cut the obd-1 plugs off the distributor and put it on the obd-0 distributor? will that even work? or do i change the plugs on the harness side to obd-0 plugs?? anyone who's done this please help me...i have no idea where to find a wire harness that will work due to me being out here in lancaster/palmdale and we have really gay junk yards!!! anyone know what should i do/can do and what would be the easiest way to do this!!!!!???? thanks any info would help here!!
