Do I need to rewire for multi point fuel inject.
  • Thread starter Thread starter Automaiter
  • Replies Replies 8
  • Views Views 956
Automaiter
I have a 97 civic LX do i need to rewire for multi point fuel injection if i swap my enigne for a B-16a2???????
Thanks
i was told to move your two injector wires to diff pins on the ecu. you also have to add two more wires for the two new injectors. you will also need a resistor box for MPFI.
or at least that was what i was told
Have you even looked at your engine, if you have it should say PG-MPFI on your intakemanifold assuming you know what that is. If it says PG-MPFI then you are good.
Originally posted by lsvtec@Nov 14 2003, 08:45 PM
I am not very familiar with the Civics, but I would bet that the 97 Civic had MPFI.
Well sir, you need to go to Vegas, you'll make millions.
Originally posted by 97hatch@Nov 19 2003, 08:15 PM
:blink: correct me if im wrong but dont all 92+ civics have mpfi :unsure:
All meaning all US models, yes, not worldwide though.
