97 civic lx or dx junker
had a CEL for TDC sensor
autozone read the code as a misfire, sold my sister plugs and wires and cap...
so she changed those and then no start...
did the wires one at a time etc etc...
so then i told her she should have just gotten a dist. cause that houses the TDC sensor and they start to go bad then just die
so changed the dist. and still no start
it sputters a bit like it wants to start but nothing...
i got the firing order just to double check again on the wires...
but when she was able to get it started after the tune up the CEL light was FLASHING, not on, not off, but flashing... not codes either, just flash flash flash, wtf?
the only time i have see the CEL flash is when i left the jumper clip hooked up and started my car...
i am thinking bad ecu maybe?
the kicker is i pulled wire #4 and its got spark...
doesn;t seem like a shit load of spark, but its there non the less...
