Failing fan I think
  • Thread starter Thread starter CiViC_SOHC
  • Views Views 622
CiViC_SOHC
I am driving sometimes and my Temp just decides to go up! Like almost to the H..it normally stays about mid level I don't know why...its every once and a while im thinking its a bad relay switch but my fan kicks on when its supposed to well..that I know of I can't hear it over my flippin exhaust! It also could be my thermo sticking...need help! thanks
See thermostat, fan relay, and check and make sure your cooling system stays pressurized. Check for any leaks at all. I had about the same problem as you stated. I checked my overflow bottle, and found a leak on the oil rubber hose. I replaced it, and it runs fine.
