finished my buddys lsvtec but the motor dies when he steps on the gas!
  • Thread starter Thread starter civiclxb16
  • Replies Replies 21
  • Views Views 3K
Pull the crank pulley off and see exactly where the oil is leaking from.
Did you replace the oil pump? You know you should becuase 96+ b series oil pumps flow more volume than the earlier models...
found it it was the crank seal! i replaced it and boom just a small drip from the oil pan! all set its going to be on the road tomorrow all i need is a test pipe or something for the header to reach the cat
