Hey Guys i need help.
I have a '98 Honda accord v6 with 81k miles on it.
When cold and started, the gears engages normally. But when heated up for just 3-5 minutes, the rev at idle state fluctuates between 1500 to 3500 rev/min.
Still under this condition the revers gear does not engage again. To get the revers gear, i have to switch off the engine and start again.
As soon as the rev begins to fluctuate, when I engage d4 or d3 the car jecks even when the brake is engaged and you can feel the impact as if you are engaging a manual transmission without the clutch.
The car literally drives itself with the leg out of the throttle.
When N or p the rev is between 1500 to 3500 rev/min. but when loaded it stabilizes at 1400 rev/ min
Any suggestion will be appreciated phil
