Story of the engine
GSR USDM B18C1 BLOCK WITH MAIN BEARING CAP / PISTON OIL SQUITTER / OIL PAN / OIL PICK UP/ oem New water pump/ oem new oil pan gasket/ OIL COOLER
Block is bored to 81.50mm n honed n Deck to provide perfect sealing of the head by RS MACHINES
The block is PERFECT, NO heli coil $550
TYPE R oem head gasket (Brand New) $70
GSR cylinder heads, 3 angled radius valve job, new oem valve seals, resurface and assembled (rs machines)
Vtec solenoid, GSR Oem Valve Cover is included $700
GSR Crankshaft Balanced n Micro Polished $225
GSR Oem main bearing upper n lower, color brown, black,green, blue $9 each (BRAND NEW)
TYPE R Oem oil pump $100
GSR 5 spd half shaft $55
AC Bracket $20 / PS bracket / PS PUMP $30 / OEM Rear mount $25
OEM altenator $30 / OEM starter $30
COULD PART IT OUT OR SELL COMPLETE
PLS PM ME for info or pict
714 785-4344
PLS BUMP<
NEED TO SELL ASAP<
WORKING OVERSEAS IN A COUPLE WEEKS
714 785-4344
PLS BUMP<
NEED TO SELL ASAP<
Drop The Price On The Head
