fs/ft 91 civic si zc turbo also ls swap
  • Thread starter Thread starter caliguynsc
  • Replies Replies 15
caliguynsc
looking to get $4,000 obo
i have a 91 civic si sohc zc turbo w/ fmic also have an 91 ls swap for it. swap was done at 160,000 and turbo at 168,000.car as 172,xxx.
-SOHC ZC swap from hmo with 45,000 miles
-Air Reasearch .42/.48 T3 -shaftplay is tighter than prom night
-Stainless Steel 2.5" KTeller exhaust, and DP. Magnaflow 18" resonator. Ends right at the alxe.
-CCA Intercooler modified to backdoor
-Converted To Obd-1
-Hondata S100b
-PLX M-300 WB
-Findaza Light weight Flywheel
-Real Greddy Type S BOV
- Real TiAL 38mm wastegate with 5,7, and 9 PSI springs
-APT Oil lines, feed fitting and return fitting.
-Factory oil cooler
-Slimfan
-B&M short shifter
-DC teg center console
-hot side piping= 2", cold side piping=2.5"
-Prototype Tuner Toys Vacuume Manifold
-Rear disk brakes
-hawk pads up front
-Boost and electric oil pressure guage
-Arp Head studs
-Oil sandwich for turbo feed/oil pressure sender
-9psi at 2.9k
-d spot intake
-dsm 450cc
-ls tb
Bad
Driverside fender is Dead
Hood is flat black
Driverside seat is torn like all other Ef driver seats.
No AC
Rear defroster work somtimes
dents and scratches form being a 16 year old car.
Good
NO RUST AT ALL
Working sunroof.
10k on clutch
10K on goodyear tires
10k on new front brakes
also have 91 ls swap full swap 96,000 miles i'm just missing the obd 1 dizzy and turbo manifold,and likeage, i have a 91 teg linkage a bit long
here are some pics
new pics
here are so new pics of the car
i just pm'd you get back to me whenever possible
